p11
Banned
-- Company:
-- Engineer:
-- Create Date: 14:30:01 05/25/2015
-- Design Name:
-- Module Name: count - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity count is
Port (
reset : in STD_LOGIC;
output : out STD_LOGIC_vector (1 downto 0);
clk : in STD_LOGIC);
end count;
architecture Behavioral of count is
begin
process (clk,reset)
variable y: STD_LOGIC_vector (1 downto 0):= "00";
begin
if (reset ='0') then
if (rising_edge(clk)) then
y := y+"01";
else
end if ;
output (1 downto 0) <= y (1 downto 0);
else
output (1 downto 0) <= "00";
end if;
end process;
end Behavioral;
WARNING:Security:42 - Your software subscription period has lapsed. Your current
WARNING:Security:42 - Your software subscription period has lapsed. Your current version of Xilinx tools will continue
WARNINGar:100 - Design is not completely routed. There are 8 signals that are not
completely routed in this design. See the "count.unroutes" file for a list of
all unrouted signals. Check for other warnings in your PAR report that might
indicate why these nets are unroutable. These nets can also be evaluated
in FPGA Editor by selecting "Unrouted Nets" in the List Window.
WARNINGrojectMgmt - File D:/VHDL_14.4/lcd1/lcd1.stx is missing.
this is a design of a 2 bit counter . the test bench waveform is absoluytely correct but , cant implement the design. i think i should not have initiated the variable value with 00, as its unnecessary , but still cant understand the reason behind this warning.
