iamlearning
Junior Member level 1
Hi!
I am trying to install cadence IC610 in Scientific Linux 5. I installed it successfully through Installscape and also installed the Open Access, configured as well after the installation.
First two lines of my license file are:
SERVER SERVER.VLSI-LAB ANY 27000
DAEMON cdslmd /home/VLSI/cadence/tools/bin/cdslmd
Now, I am trying to set up the environment. To do it, I copied the .cdsinit and the .cshrc files in my home directory and appended the following lines to the .cshrc file:
export CDS_ROOT = /home/VLSI/cadence
export CDS_INSTALL_PATH=$CDS_ROOT/tools/dfII/
export CDS_LIC_FILE=27000@SERVER.VLSI-LAB
export LM_LICENSE_FILE=$CDS_ROOT/share/license/license.dat
export PATH=$PATH:$CDS_ROOT/tools/bin:$CDS_INSTALL_PATH/bin:$CDS_ROOT/tools/spectre/bin
export LANG=C
export CDS_Netlisting_Mode=Analog
alias lmli= '/home/VLSI/cadence/tools/bin/lmgrd-c/home/VLSI/cadence/share/license/license.dat'
But, the problem is, my terminal window identifies the 'export' as unknown commands, because I am using C-shell. Could anyone please suggest me what commands can I use instead of them? I am confused about where to use setenv, where set path and whether shall I need to change alias lmli.
Anyone kindly put some light to clarify the issue.
Thank you ...
export LANG=C
Thank you ...
