[SOLVED] Encoding of a slave-slect signal
dpaul
Advanced Member level 5
Germany
Take the case of an in-circuit bus system which has multiple slaves. Each slave will have a fixed memory map area. In most cases there will be an address decoder whose input is the address information from the master. This address decoder then generates slave select signals as per the address bus value.
I have seen in many cases that these slave select signals are of the encoding 001, 010, 100 accommodating 3 slaves. Why is this majorly followed?
If I generate a 3 bit slave select o/p signal, I can in principle control 8 slaves if I use the encoding 000, 001, 010...111.
I would like to know if a standard encoding scheme is followed and why?
The slave select can then be used without further decoding as it's not encoded. This is done to reduce the amount of logic and improve the timing (due to reduced logic) at the slave.
And this works great for slower interfaces, with a small number of slaves. What happens if you have 256 slaves? Do you use an 8-bit bus and route that to 256 slaves or do your decode 256 slave selects and have only 256 single point to point connections routed around your chip?
Reactions: dpaul
    dpaul
ok, thanks!
The thing to be considered is the no. of slaves to be connected and better to consider scalability of the design.
