Enable again on orcad autoroute finished
suromenggolo
Full Member level 1
orcad layout autoroute
On Orcad layout, on running autoroute board if it has finished, warning 'All Sweeps completed (or disabled)'. So running autoroute board again is disable.
If I unroute one some track, and running autoroute board again it is disable too...
How to enable autoroute board again..?
THX
orcad autoroute
I have also faced such problems in the past, what i think is u need to change some of the Autoroute settings, also if u delete one of the report files generated (whixh i think is a text file or another such thing) might help.
But frst check the autoroute settings.
orcad layour autoroute
Option -> Route Strategies -> Route passes -> Select what you want (or just double click the header coloumn "Name" to select All) - edit properties -> uncheck "Done" check box.
HTH
orcad layout 16 autorute
You can also go to the menu: View/Zoom DRC/Route Box and select all your board, then go to: Auto/Autoroute DRC/Zoom Box.
I hope it helps...
