victordion
Newbie level 6
I am doing the math modeling of the regulator's efficiency and hoping someone can help me.
What I am studying is a boost mode regulator by Linear. Its datasheet gives an efficiency chart as shown. I guess the efficiency should be a function of V_in, V_out, I_out, Namely, E = f(V_in, V_out, I_out).
1. Suppose we connect a constant voltage source providing V_in to the regulator's input, and connect a super capacitor (whose initial voltage is within regulator's rated output voltage [V_out_min, V_out_max]), so V_out grows as the charging process goes on. Then what will be I_out? Will this always be the regulator's maximum rated output current?
2. Suppose the constant voltage source providing V_in to the regulator's input is replaced by a PV cell which has its I-V characteristics I_in = g(V_in), and the super capacitor configuration is the same as above. How can we determine I_out over time?
What I am thinking is, we have the following relations hold:
I_in = g(V_in);
E = f(V_in, V_out, I_out);
E = (V_out*I_out)/(V_in*I_in)
V_out = Integral(I_out)dt/C + V_out_0;
There are 5 variables (E, V_in, V_out, I_in, I_out), and only 4 equations, I feel that if I_out is fixed, we can solve all variable.
I_in = g(V_in);
