edit a file using a lower version?
hemanthbeera
Newbie level 3
bangalore
how to edit cadence pcb file created in high version(16.5), in a lower version(16.3)?
Raza
Advanced Member level 3
PAK
Editing in lower version not advisable, as khanna said you will lose design rule data and the file may have to be recreated.
Raza
PAK
Hi hemanthbeera,
That is good you found the solution. Now for the sake of help other, why do not you share it here, if possibel ?
Anonymous_Ricky
Advanced Member level 2
India
Hi hemanthbeera,
goto file >>export>>save to****(select the 16.3 version)
I think you can directly down convert the file to version in 16 sereies only, just check that, I am not sure about it
Raza
PAK
Yes you are right. That is SAVE AS file menu option.
That is good, thanks for.
khanna_gunjan
Member level 3
Nürnberg, Germany
After you made your changes, did you tried opening/converting the file again with the higher version?
I doubt it would work without problems.
