Eagle v4.11 problem with infinite lines of some packages
Hedgehog
Newbie level 3
Eagle v4.11 problem
Hello!
I've got a broblem using Eagle v.4.11 for Windows .
Some packeges from different libraries in the layout mode have infininite lines. May I ask to help me. Please.
mip
Member level 2
Re: Eagle v4.11 problem
Sorry, I can't help you directly, but you should address this problem to the developers und support team of Cadsoft.
You can find them on Usenet news.cadsoft.de in eagle.support.*
mrcube_ns
Advanced Member level 1
Europe
So many views but no one replies..... very shame!
I suppose I'm not the only one which dont understand what is your problem. Be more specific and your get right answer to your problem.
Mr.Cube
Hedgehog
Newbie level 3
Some of viewer understood my point correctly and helped me.
Thanks to everyone. Everything work fine!
pool_77
Full Member level 3
EU
reinstal eagle.
If you have this problem, you can find if you export lbr and import again.
I solve it by reinstalling eagle
(You maybe have another ver. of eagle installed on PC)
pool_77
anelar
Newbie level 6
Eagle v4.11 problem
Is there any other solution than reinstalling EAGLE?
pool_77 > I don't understand what you are saying about export lbr and import again. Are you saying this problem appears when you export?
My desciption of the problem:
In schematic I get some infinite lines originating from curved lines in certain symbols. For example in con-subd.lbr almost all devices have curved lines in these symbols and therefore somehow gets corrupt.
Thnx in advance!
//Swedish guy
hcet
Full Member level 5
to make a long alley short:
h**p://www.cadsoft.de/forum.htm ->eagle.support.eng
pool_77
Full Member level 3
EU
I mean that you can test this problem by exporting and then importing LBR
pool_77
rauol
Full Member level 6
India
Try deleting the Eagleerc.usr file from " my documents"
i faced a problem, all the holes in the pads were closed and reloaded eagle ad Dozen times, with no effect. then i deleted that file and everything was alright.( eagle will create a fresh file of eagleerc.usr)
otuzsubat
Member level 4
istanbul, Turkey
Eagle v4.11 problem
i'm solving this problem by editing the library files. anyway some of the part whish i use are damaged. for example bc546 end led5mm.
in addition, i sometimes complete pcb drawing and then delete this damaged parts. then i use vias instead of pads.
