Dummy position question
madalin1990
Full Member level 2
Full Member level 2
It is correct to place a dummy transisitor between the drain and the source of an another transistor?(with his gate connected to vdd)
It is perfectly fine as some times we put a dummy in btwn two matched transistors to get accurate matching pattern. So it should be perfectly fine in using a dummy in this case.
OR Dummy can be done by shorting D,S and Gate. And by connecting to transistors Source.
