DSK6713 with MATLAB on Windows 7
nikolov
Newbie level 3
Bulgaria
Hi everybody,
First of all I want to thank to you all, because of the knowledge center that this site is. And I am very sorry that I don't still have the skills to contribute too.
I have to make a GUI interface in MATLAB which has to implement FIR or IIR filters (based upon user selection) on a target board DSK6713. And the difficulty I have is:
I have Windows 7 , Matlab 2009,2010 and CCS 3.3 , CCS 4 .. is it possible to connect MATLAB with the target board using one of the following CCS packages (on windows 7) and if it is possible, what is the procedure (or the name of the protocol or function..)
I can connect the board with Matlab BUT on WinXP .. which is not acceptable in my case.
Thank you for your patience.
Hi Nikolov,
I had been breaking my head since past 4-5 months going through the same problem. Actually CCS 3.3 does not recognize Win7. Hence its not possible to work on Win7 with CCS 3.3. Even TI advises to move to CCS v4. For installation please go through the manual below. It helped me a lot.
  • c6713dsk2.installation.pdf
Thank you for the response.
But I have already got CCS 4 working ... and connecting to target. But the main problem is that it can not connect using MATLAB :(
All sources I read they say that CCS4 and above do not support MATLAB linking... is that true ?
Thank you again.
Thank you very much.
That is possible with Windows 7 right ?
