engineer1000
I have been using a generator with the output from the transformer being connected to an inductor in series with the transducer making an LC resonant cct. The output from the generator is approx 250V unloaded.
When I attach the transducer to it and find a resonant frequency ( one being 119khz) the current goes up and the pk pk Voltage across the transducer also goes up to about 1.4kv ( the transdcuer is ringing)
The problem is I want to run the transducer loose, when I do this it gets very hot very quickly.
Now if I remove the inductor and connect the transducer directly to the output of the transformer I get a sort of 200V square wave.
To my supprise this is just enough to get some activity out of the transducer.
I don't understand how it is working as its not ringing can anyone help?
