sriblue7
I have some doubts regarding the design of a 100w inverter
1)is it possible to use 12v 4.5Ah Lead acid battery to provide 5hrs supply continuously?As 100W requires 0.5A(100W/220V) at the output,can i use the above battery along with some MOS amplifiers such as P55NF06(to provide a amplification of ~12 times([0.5*20(turns ratio)]/0.9))?
2)If i connect two 12V 4.5Ah lead acid battery in parallel will the Ampere-hour rating be 9Ah?
3)What is the difference and use of MOS in H-bridge configuration and push-pull configuration?
3)Where should the PWM signal be filtered to get sine wave (input/output side)and how?
Thanks in advance..........
