doubts in circuit diagram of LPC2148
embpic
Advanced Member level 3
india
hello master's
i am using lpc2148 and using arm dev. board but i need to design for my project. and i have some doubts in design as follows.
1. I want to use supply which is optional whether to from USB or +5v DC power supply from wall socket.
2. if I connect vcc of USB to Vcc of Power supply and I am using both USB and external power supply then will it harmful to PC?
or I have to keep it isolated from each other.
3. how to include ISP & J-TAG debugging (10-pin) for loading firmware.
4. also thinking to add microSD in design.
i have attached circuit diagram which was got with dev board. and i am using it for core.
sir i have post a circuit of dev board which was in pdf and i need to design a new PCB for my projects. and i am giving to professional PCB designer.so i have theses doubts to design for me.
any one designed This one plz help this is urgently.
One power supply should not be allowed to contact the other power supply. You should use steering diodes, or a relay, or a 3-conductor auto-switch jack, etc.
If you could be sure the supplies would never be at uneven volt levels, it would theoretically be okay. However it is too risky to your expensive equipment.
It is difficult to provide an in-depth critic of your design due to the low resolution of the uploaded image.
However, there definitely seems to be a lack of the necessary bypass caps on the power lines of the LPC2148.
Why not save yourself some frustration and concern, by adapting one of the myriad of available schematics of known reliable design for a LPC2148 dev board?
For example:
Olimex LPC-P2148 Product Page
LPC-P2148 Schematic
Also checkout the NXP website as they typically offer extensive reference material on best practices for designs which utilize their products like the LPC2148.
Topics like bypass cap requirements, suggestion for crystal location, PCB design, etc, are typically covered in-depth.
BigDog
thank you sir,
i have uploaded pdf file which is got with dev. board and i have selected some part from that circuit.
like
power supply
power led
I2C eeprom
sd interface
and all from third box.
sir i refer some schematic and found that it is related and same with this one.
here i have attached pdf
  • Dev_Board.pdf
