abu9022
Member level 3
Hi Friends,
when I am running vsim tb_func32 -do "run -all" in modelsim, running for 30 minutes still didnt get final output
I dont know much about modelsim, I have doubt what I am doing is correct or something wrong?
time (is increasing): 222, 331, 830 ns (current time) Delta:2 sim :/tbleon
# vsim -do {run -all} tb_func32
# Loading std.standard
# Loading ieee.std_logic_1164(body)
# Loading work.target
# Loading ieee.std_logic_arith(body)
# Loading work.device
# Loading std.textio(body)
# Loading work.config
# Loading work.mmuconfig
# Loading work.sparcv8
# Loading work.iface
# Loading work.tblib
# Loading work.leonlib
# Loading ieee.std_logic_unsigned(body)
# Loading work.debug(body)
# Loading work.tb_func32
# Loading work.tbleon(behav)
# Loading work.tbgen(behav)
# Loading work.tech_map
# Loading work.leon(rtl)
# Loading work.amba
# Loading work.ambacomp
# Loading work.mcore(rtl)
# Loading work.rstgen(rtl)
# Loading work.ahbarb(rtl)
# Loading work.apbmst(rtl)
# Loading work.fpulib
# Loading work.proc(rtl)
# Loading work.macro(body)
# Loading work.multlib
# Loading work.iu(synth)
# Loading work.iu_verilog1
# Loading work.iu_syn_updated
# Loading work.AND2_X1
# Loading work.OR2_X1
# Loading work.OR4_X1
# Loading work.OR3_X1
# Loading work.OAI33_X1
# Loading work.NOR2_X1
# Loading work.INV_X1
# Loading work.DLH_X1
# Loading work.XOR2_X1
# Loading work.NAND2_X1
# Loading work.AOI22_X1
# Loading work.AOI21_X1
# Loading work.NOR3_X2
# Loading work.NOR2_X2
# Loading work.INV_X4
# Loading work.NAND2_X2
# Loading work.AND3_X4
# Loading work.AND2_X4
# Loading work.NOR2_X4
# Loading work.OR2_X4
# Loading work.BUF_X4
# Loading work.INV_X16
# Loading work.OAI22_X2
# Loading work.OAI211_X4
# Loading work.MUX2_X2
# Loading work.DLH_X2
# Loading work.INV_X8
# Loading work.AND4_X4
# Loading work.NAND2_X4
# Loading work.OR3_X4
# Loading work.XNOR2_X2
# Loading work.OAI211_X2
# Loading work.MUX2_X1
# Loading work.OAI221_X2
# Loading work.OAI21_X1
# Loading work.AND3_X2
# Loading work.OAI21_X2
# Loading work.NAND3_X1
# Loading work.OAI211_X1
# Loading work.OAI22_X1
# Loading work.NOR3_X1
# Loading work.OAI222_X1
# Loading work.INV_X2
# Loading work.NOR4_X1
# Loading work.AND2_X2
# Loading work.AOI211_X1
# Loading work.NAND4_X1
# Loading work.OR2_X2
# Loading work.AOI22_X2
# Loading work.AOI21_X2
# Loading work.NAND3_X2
# Loading work.AOI211_X2
# Loading work.AOI221_X2
# Loading work.NOR4_X2
# Loading work.OAI222_X2
# Loading work.AOI222_X1
# Loading work.AND4_X2
# Loading work.AOI221_X1
# Loading work.XNOR2_X1
# Loading work.NAND4_X2
# Loading work.iu_DW01_inc_1
# Loading work.XOR2_X2
# Loading work.iu_DW01_add_5
# Loading work.iu_DW01_add_4
# Loading work.iu_DW01_add_3
# Loading work.NOR3_X4
# Loading work.NAND3_X4
# Loading work.OAI21_X4
# Loading work.AOI21_X4
# Loading work.iu_DW01_sub_1
# Loading work.iu_DW01_cmp6_5
# Loading work.iu_DW01_cmp6_4
# Loading work.iu_DW01_cmp6_3
# Loading work.iu_DW01_cmp6_2
# Loading work.iu_DW01_cmp6_1
# Loading work.iu_DW01_cmp6_0
# ** Warning: (vsim-PLI-3003) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_verilog1.v(37): [TOFD] - System task or function '$set_gate_level_monitoring' is not defined.
# Region: /tbleon/tb/p0/leon0/mcore0/proc0/iu0/iu1
# ** Warning: (vsim-PLI-3003) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_verilog1.v(38): [TOFD] - System task or function '$set_toggle_region' is not defined.
# ** Warning: (vsim-PLI-3003) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_verilog1.v(39): [TOFD] - System task or function '$toggle_start' is not defined.
# ** Warning: (vsim-PLI-3003) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_verilog1.v(44): [TOFD] - System task or function '$toggle_stop' is not defined.
# ** Warning: (vsim-PLI-3003) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_verilog1.v(45): [TOFD] - System task or function '$toggle_report' is not defined.
# Loading work.tech_atc18
# Loading work.tech_atc25
# Loading work.tech_atc35
# Loading work.tech_fs90
# Loading work.tech_umc18
# Loading work.tech_generic
# Loading work.tech_virtex
# Loading work.tech_virtex2
# Loading work.tech_tsmc25
# Loading work.tech_proasic
# Loading work.tech_axcel
# Loading work.regfile_iu(rtl)
# Loading work.virtex2_regfile(behav)
# Loading work.virtex2_complib
# Loading work.virtex2_dpram(behav)
# Loading work.ramb16_s36_s36(behav)
# Loading work.ram16_sx_sx(behav)
# Loading work.cache(rtl)
# Loading work.icache(rtl)
# Loading work.dcache(rtl)
# Loading work.acache(rtl)
# Loading work.cachemem(rtl)
# Loading work.syncram(behav)
# Loading work.virtex2_syncram(behav)
# Loading work.ramb16_s36(behav)
# Loading work.generic_syncram(behavioral)
# Loading work.dpsyncram(behav)
# Loading work.ramb16_s9(behav)
# Loading work.dsu(rtl)
# Loading work.dsu_mem(rtl)
# Loading work.dcom(struct)
# Loading work.ahbmst(rtl)
# Loading work.dcom_uart(rtl)
# Loading work.mctrl(rtl)
# Loading work.lconf(rtl)
# Loading work.timers(rtl)
# Loading work.uart(rtl)
# Loading work.irqctrl(rtl)
# Loading ieee.std_logic_signed(body)
# Loading work.ioport(rtl)
# Loading work.clkgen(rtl)
# Loading work.generic_clkgen(rtl)
# Loading work.smpad(rtl)
# Loading work.gensmpad(rtl)
# Loading work.inpad(rtl)
# Loading work.geninpad(rtl)
# Loading work.outpad(rtl)
# Loading work.genoutpad(rtl)
# Loading work.iopad(rtl)
# Loading work.geniopad(rtl)
# Loading work.smiopad(rtl)
# Loading work.iram(behavioral)
# Loading work.testmod(behav)
# Loading work.seq1
# ** Warning: (vsim-3017) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11351): [TFMPC] - Too few port connections. Expected 5, found 4.
# Region: /tbleon/tb/p0/leon0/mcore0/proc0/iu0/iu1/iu2/add_554
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11351): [TFMPC] - Missing connection for port 'CO'.
# ** Warning: (vsim-3017) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11372): [TFMPC] - Too few port connections. Expected 5, found 4.
# Region: /tbleon/tb/p0/leon0/mcore0/proc0/iu0/iu1/iu2/add_1612
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11372): [TFMPC] - Missing connection for port 'CO'.
# ** Warning: (vsim-3017) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11384): [TFMPC] - Too few port connections. Expected 5, found 4.
# Region: /tbleon/tb/p0/leon0/mcore0/proc0/iu0/iu1/iu2/add_1_root_add_1594_2
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11384): [TFMPC] - Missing connection for port 'CO'.
# ** Warning: (vsim-3017) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11396): [TFMPC] - Too few port connections. Expected 5, found 4.
# Region: /tbleon/tb/p0/leon0/mcore0/proc0/iu0/iu1/iu2/sub_1_root_sub_1593_S2_2
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11396): [TFMPC] - Missing connection for port 'CO'.
# ** Warning: (vsim-3017) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11401): [TFMPC] - Too few port connections. Expected 9, found 4.
# Region: /tbleon/tb/p0/leon0/mcore0/proc0/iu0/iu1/iu2/eq_1079_2
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11401): [TFMPC] - Missing connection for port 'LT'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11401): [TFMPC] - Missing connection for port 'GT'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11401): [TFMPC] - Missing connection for port 'LE'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11401): [TFMPC] - Missing connection for port 'GE'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11401): [TFMPC] - Missing connection for port 'NE'.
# ** Warning: (vsim-3017) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11406): [TFMPC] - Too few port connections. Expected 9, found 4.
# Region: /tbleon/tb/p0/leon0/mcore0/proc0/iu0/iu1/iu2/eq_1076_2
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11406): [TFMPC] - Missing connection for port 'LT'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11406): [TFMPC] - Missing connection for port 'GT'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11406): [TFMPC] - Missing connection for port 'LE'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11406): [TFMPC] - Missing connection for port 'GE'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11406): [TFMPC] - Missing connection for port 'NE'.
# ** Warning: (vsim-3017) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11409): [TFMPC] - Too few port connections. Expected 9, found 4.
# Region: /tbleon/tb/p0/leon0/mcore0/proc0/iu0/iu1/iu2/eq_1061_2
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11409): [TFMPC] - Missing connection for port 'LT'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11409): [TFMPC] - Missing connection for port 'GT'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11409): [TFMPC] - Missing connection for port 'LE'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11409): [TFMPC] - Missing connection for port 'GE'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11409): [TFMPC] - Missing connection for port 'NE'.
# ** Warning: (vsim-3017) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11412): [TFMPC] - Too few port connections. Expected 9, found 4.
# Region: /tbleon/tb/p0/leon0/mcore0/proc0/iu0/iu1/iu2/eq_1058_2
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11412): [TFMPC] - Missing connection for port 'LT'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11412): [TFMPC] - Missing connection for port 'GT'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11412): [TFMPC] - Missing connection for port 'LE'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11412): [TFMPC] - Missing connection for port 'GE'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11412): [TFMPC] - Missing connection for port 'NE'.
# ** Warning: (vsim-3017) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11416): [TFMPC] - Too few port connections. Expected 9, found 4.
# Region: /tbleon/tb/p0/leon0/mcore0/proc0/iu0/iu1/iu2/r820
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11416): [TFMPC] - Missing connection for port 'LT'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11416): [TFMPC] - Missing connection for port 'GT'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11416): [TFMPC] - Missing connection for port 'LE'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11416): [TFMPC] - Missing connection for port 'GE'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11416): [TFMPC] - Missing connection for port 'NE'.
# ** Warning: (vsim-3017) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11419): [TFMPC] - Too few port connections. Expected 9, found 4.
# Region: /tbleon/tb/p0/leon0/mcore0/proc0/iu0/iu1/iu2/r819
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11419): [TFMPC] - Missing connection for port 'LT'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11419): [TFMPC] - Missing connection for port 'GT'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11419): [TFMPC] - Missing connection for port 'LE'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11419): [TFMPC] - Missing connection for port 'GE'.
# ** Warning: (vsim-3722) /mnt/iscsi/Users/ee5113/zxv764/vsim/leon2-1.0.30-xst/leon/iu_syn_updated.v(11419): [TFMPC] - Missing connection for port 'NE'.
# run -all
# LEON-2 generic testbench (leon2-1.0.30-xst)
# Bug reports to Jiri Gaisler, jiri@gaisler.com
# Testbench configuration:
# 32 kbyte 32-bit rom, 0-ws
# 2x128 kbyte 32-bit ram, 2x64 Mbyte SDRAM
