Doing timing analysys in PT without .libs
wipshami
Member level 1
Member level 1
Can I do a timing analysis for the complete top level design including IO with the .libs for IO and spiceNetlist of the MACRO ?
* The top level design is not having any std.cells only MACROs
I am not having .lib models for the MACRO ? are they essential for PT run ? If yes, Can I write out .libs for these MACRO from virtuoso ? (MACRO are designed full custom in virtuoso)
Thanks
Shameel
Primetime requires .db (compile .lib file) to work.
Virtuoso could not generate .lib file, you need a characterisation tool for that.
Can we do the timing analysis for transistor level custom block in PT after generating .lib using characterisation tool ? Is that the right way ?
or we need to go with tools like nanotime to do transistor level STA ?
Yes, with characterization tool you could generate the liberty file from spice netlist (transistor model).
I don't know nanotime.
