Does this simple circuit give voltage to Vdd?
cadenceUK
Member level 5
I saw this circuit somewhere!
Please tel me if it is meant to give voltage to Vdd in the main circuit using Vdd.?
Re: A simple circuit!
ya.... that is the purpose of such a representation....
A simple circuit!
Do we need to use this in every level of schematic.
For eg:
I created an inverter which is sub part of a ring oscillator..
Now, Do i have to give supply to BOTH > the individual inverter and Ring oscilator( chain of inverters)?
If i give it to ring oscillator it works fine but when i debug the circuit and check the output of individual inverter it gives wrong output for every inverter.
A simple circuit!
no put it at the very top level, in your case the schematic of the ring oscillator. if you want to test just one inverter, create a new schematic with just the inverter symbol with the vdd-vdc-gnd circuit and simulate. or replace vdd with vdc=3.3 (or whatever your technology uses) in the schematic of inverter.
I am using this circuit and get output in mV on 1st inverter!
A simple circuit!
why are there output pins? is this the top level or there is this the schematic of a symbol? make sure all pmos source is tied to vdd (from basic library, symbol) and in top level you have the vdd-vdc-gnd circuit. if you are really struggling, tie all pmos to vdc=1.8. does the opamp give output? Vid seems to be zero.
A simple circuit!
it is top level!
Added after 6 minutes:
all pmos r tied to vdd and nmos to gnd!
when i add vdd-vdc-gnd circuit on this level as said by u...
i cant get the output on 1st inverter .... it gives output in mV
then i think tht there may b problem in inv and add vdd-vdc-gnd circuit
in the inverter level....
bt then
cadence gives error.... m confused:(
A simple circuit!
does it work by tying all pmos sources to voltage sources?
Shud I enter Supply in this level of invertor OR the top level as shown above?
A simple circuit!
please tell where i should use this supply .... as given in the above inverter or in the top level?
thanks!
Added after 29 minutes:
ne comments :)?
either would work, people generally put in the top circuit because of convenience
A simple circuit!
You can use the supply in the top level
VDD is usually used in the top view.
