does monopole antenna need a ground plane?
roronoa
Junior Member level 2
monopole antenna
hi everyone, im assigned to a project which need to built a monopole antenna.
What i want to ask is, does monopole antenna need a ground plane or it can be directly connected to the LC tank ?
Thanks for your reply
biff44
Advanced Member level 5
New England, USA
Re: monopole antenna
Yes and no. A quarter wave monopole needs some sort of ground plane. That ground plane might be a piece of metal on the circuit board, the shield on a coax cable, or the body of a person holding the unit. How well the ground plane works determines the radiation efficiency and radiation pattern.
Other types of antennas, such as a sleeve type coaxial half-wave antenna, do not require any sort of ground plane at all.
roronoa
biff44,thx for ur reply.is there any antenna that is simple to construct,high in gain and does not need a ground plane?
