Documents about implementing USB based devices for beginners
brmadhukar
Advanced Member level 3
India
I have the "USB in a nut shell", available at xxx.beyondlogic.org. Are there anyother similar documents. I need something from which I can implement a simple USB based device.
TIA
brmadhukar
mami_hacky
Full Member level 6
Full Member level 6
Some where
usb osi
I have a full CD, containing books, documents, standards and some development tools for USB. if any one needs, I can share.
Reactions: gafsos
    gafsos
juripero
Member level 4
Member level 4
osi model usb
check out the following: usb design by example
a great book on usb
A
artigas
Newbie level 1
usb logical relation with iso model
I need some thing reference with USB and MP3 player anyone have some thing about
verilog
Member level 1
Member level 1
VN
usb are on what layer of the osi model
I have designed USB interface 3 years ago. USB by example is a good book. Especially for beginner.
uranus
Newbie level 1
Newbie level 1
usb osi-layer
It's useful. Thanks.
/ Warning #2 - No thanks here! /
usbman
Full Member level 1
Germany
usb+osi
Atmel has a single chip usb solution with mp3 support.
The chip has a 8051 mcu, lcd interface, smart media interface and many more. Search for 89c51SND1
usbman
Hemmos
Newbie level 3
Newbie level 3
osi model usb protocols
in order to implenment a usb device , you must ask yourself :
do ou need to implement on Chip device or your are going to use a microcontroller ?
for on chip devices , there is a good url that contains small projects on usb on VHDL :
www.opencores.org
if you are going to use a microcontroller a suggest you read usb by example carefully
womiga
Newbie level 1
Newbie level 1
iso osi-layer universal serial bus
usb2.0
visualart
Advanced Member level 1
usb protocol beginner
Hi, Dear mami_hacky
I need some usb tool ,you cam help me?
Thx
visualart
pan
Newbie level 1
Newbie level 1
osi usb
a great book on usb
Dear Sir,
The address you told me didn't exist indeed.Please help me.
Thanks, 8O
arcaphill
Member level 5
Member level 5
usb osi modell
Some useful thing! :D
arcaphill
Member level 5
Member level 5
usb and osi model
USB On The Go Spec!
arcaphill
Member level 5
Member level 5
best usb electronics beginner
Other :D :D :D
micro325
Junior Member level 2
osi usb layers
If you want to study and analyze the USB protocol,
you may use the protocol analyzer 'Bushound' from www.perisoft.net
This is a simple but very strong 'software bus analyzer' at windows.
This shows the all Endpoint packets.
I did study the usb protocal using this program.
ireennet
Newbie level 1
Newbie level 1
modelo osi usb
Can anyone send an example of simple USB usage?
nachus001
usb osi layer
Hi, check this:
usb device implemented in AT90S2313 (firmware!!! no usb controller needed)
follow all links on the inside are usefull!
Nachus
