gbounce
Junior Member level 3
modelsim doesn't complain when i instantiate the clock buffer like this:
when i go to synthesis using synplify, it errors out with the message: Instantiated entitty axcelerator.hclkbuf has not been analyzed.
if i change to whats below it works fine.
synplify is linked to the axcelerator library properly and it shows up under the design hierarchy. it appears it should compile in the proper order. any ideas?
library axcelerator;
use axcelerator.hclkbuf;
inst_hclkbuf : entity axcelerator.hclkbuf
port map (
pad => clk_in,
y => clk_out
component hclkbuf
port (
pad : in std_logic;
y : out std_logic
inst_hclkbuf : hclkbuf
port map (
pad => clk_in,
y => clk_out
