Digital image processing
JPEG 2000 is an image compression standard and coding system. It was created by the Joint Photographic Experts Group committee in 2000 with the intention of superseding their original discrete cosine transform-based JPEG standard (created in 1992) with a newly designed, wavelet-based method. Progressive transmission by pixel and resolution accuracy, commonly referred to as progressive decoding and signal-to-noise ratio (SNR) scalability: JPEG 2000 provides efficient code-stream organizations which are progressive by pixel accuracy and by image resolution (or by image size). This way, after a smaller part of the whole file has been received, the viewer can see a lower quality version of the final picture. The quality then improves progressively through downloading more data bits from the source. The 1992 JPEG standard also has a progressive transmission feature but it's rarely used.The aim of JPEG 2000 is not only improving compression performance over JPEG but also adding (or improving) features such as scalability and editability. In fact, JPEG 2000's improvement in compression performance relative to the original JPEG standard is actually rather modest and should not ordinarily be the primary consideration for evaluating the design. Very low and very high compression rates are supported in JPEG 2000.
