azarutz
Member level 2
hi my digital clock program compiled without error , but didnt get the output .
is anything i leave it?..
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 #include <pic.h> //#include <htc.h> #define RS RB0 #define RW RB1 #define E RB2 void picinit(void); void lcdinit(void); void senddata(char); void command(char); void delay(int); void interrupt ISR(); int sec=0,min=0,hr=0,c,d,e,f,g,h,i=0; void main() { GIE=1; // Global interrupt enable TMR0IE=1; TMR0=0x00; TMR0IF=0; picinit(); lcdinit(); OPTION_REG=0b00000111; while(1) { command(0x80); //star position at 1st row nd 1st column c=hr%10; hr=hr/10; d=hr%10; e=min%10; min=min/10; f=min%10; g=sec%10; sec=sec/10; h=sec%10; senddata(0x30+d); senddata(0x30+c); senddata(0x3a); senddata(0x30+f); senddata(0x30+e); senddata(0x3a); senddata(0x30+h); senddata(0x30+g); //senddata(0x36); } } void interrupt ISR() { if(TMR0IE==1 && TMR0IF==1) { TMR0IF=0; i++; //display(); if(i==72) { sec++; if(sec==60) { min++; sec=0; if(min==60) { hr++; min=0; } } } } } void picinit() { TRISB=0x00;//B port defined as output PORTB=0x00; TRISD=0x00;//D port definrd as output PORTD=0x00; } void lcdinit() { command(0x38);//set function command(0x01);//clear display command(0x0e);//display on cursor blinking //command(0x06); } void command(char comm) { PORTD=comm; RS=0; //register select RW=0;//read or write E=1; //enable data line delay(1000); E=0; //disable data line delay(1000); } void senddata(char data) { PORTD=data; RS=1; RW=0; E=1; delay(1000); E=0; delay(1000); } void delay(int d) { int i; for(i=0;i<=d;i++); }
