Differential vs. SIngle ended Charge Pump
Engineer4ever
Member level 3
Member level 3
HI, :)
I am designing a differential charge pump, but I was thinking if it's right to use two single ended charge pumps instead of a differential charge pump, beacuse I don't want to use a CMFB circuit, so I am thinking to use two single ended charge pumps; one with input UP and DOWN and the second with input UP-BAR and DOWN-BAR, and each charge pump output will be connected to a loop filter and the outputs of the loop filters will be the differential input of the ring VCO. Is that correct?
'Charge pump' suggests you are making a voltage multiplier built from diode-capacitor (Villard) cells.
'Single-ended' suggests you are driving it from pulsed DC.
It is possible to do this, although you will need more stages to obtain a given output, whereas an AC supply would require fewer stages.
It is even possible to create a negative charge pump from DC pulses.
Alright, got it. Thanks for your answer :)
