Differential amplifier opamps common-mode gain
paulmdrdo
Full Member level 3
I'm having a hard time deriving for equations 10-8 -10-9.
i tried adding equations 10-6 and 10-7 but still can't proceed to proper derivation. Any help is appreciated.
Sometimes I put a potentiometer at the inverting input, to make it easy to vary gain.
It also helps clarify something about how gain works in the op amp: The input grabs a portion of the incoming voltage (R1) and a portion of the output voltage (R2). Somewhere in the inverse feedback relationship (somewhere) is a certain amount of gain.
That function can be defined by a simple formula (-R2/R1), but then you need to throw in the effect of the non-inverting input, making it more complicated, doesn't it?
I suppose it's possible to merge the equations into one equation for some situations but maybe not for all situations.
I guess my reply doesn't solve your question but we can see that a lot goes on within an op amp.
This might help, attached.
Regards, Dana.
  • CMR Analysis IA.pdf
  • Bob Pease Lab Notes Part 9.pdf
