Sep 29, 2018 #1 N nayakajit87 Member level 5 Joined Aug 13, 2018 Messages 84 Helped 0 Reputation 0 Reaction score 0 Trophy points 6 Activity points 1,065 Dear all. I would like to know major difference between these ICS. weather same circuit is valid both all these units max485 ----> Low-Power, Slew-Rate-Limited RS-485/RS-422 Transceivers http://www.ortodoxism.ro/datasheets/maxim/MAX1487-MAX491.pdf sn75176----> Differential Bus Transceiver http://www.tranzistoare.ro/datasheets/208/492412_DS.pdf ADM 2483 ------>differential bus transceiver http://www.analog.com/media/en/technical-documentation/data-sheets/ADM2483.pdf ADM 2483 is Isolated type , Transmit and receiving truth table are different.
Sep 29, 2018 #2 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,168 Helped 4,868 Reputation 9,757 Reaction score 5,540 Trophy points 1,393 Activity points 168,401 Hi, the first two links don´t work for me. My recommendation: Always use the datasheets directely from the manufacturers, not from second source. Second source may time out and may not be updated. At the manufacturers internet sites you will find additional documents like application notes. usually they answer all the remaining questions after you read the datasheets. Example: https://www.maximintegrated.com/en/products/interface/transceivers/MAX485.html/tb_tab2 Klaus
