Mar 23, 2010 #1 S sonofsky Junior Member level 2 Joined Jun 3, 2009 Messages 22 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,421 In electronics,we often met the two terms:active components & passive components. Can anyone give me a clear definition about the two terms:active & passive? Are they have some relationship to "linear" & "nonlinear"? Is diode an ative component or passive component? Thanks!
Mar 23, 2010 #2 V vfone Advanced Member level 6 Joined Oct 10, 2001 Messages 5,709 Helped 1,616 Reputation 3,237 Reaction score 1,248 Trophy points 1,393 Activity points 36,250 Active devices : the devices in which the electron flow( current) can be controlled electrically. Passive devices : the devices where electron flow ( current ) cannot be controlled electrically. Linear and Nonlinear generally applies to Active devices, even if there is no Passive device perfect linear. Following the above definition, diode is an Active device.
