Difference b/w Decoupling and bypass capacitors
eswar_babu77
Member level 1
Hi everyone,
can anybody explain the difference b/w Decoupling and bypass capacitors.
How does these work.
Thanks in advance.
avesat
Junior Member level 1
Ukraine
An alternative name of decoupling capacitor is bypass capacitor
jallem
Advanced Member level 1
I does not look like there is a difference
electron_boy
Full Member level 3
Chennai, India
A same cap is called different by different communities.
in AC terminology the cap actually conducts high freq noises. thus the name bypass
in DC terminilogy the cap keeps the DC voltages, applied to its terminals intact, thus the name decoupling cap.
hermesjoel
Newbie level 5
when u bias any active circuit at i/p and o/p of the device u place DC block caps! These caps allow AC to pass thru and maintain DC within the active block.
Bypass capacitor is used for AC noise bypassing mainly at the DC supply output terminals to prevent noise from supply to enter the bias block and cause disturbances in the design.
all in all, both are capacitors but different functions in different areas of the circuit.
hope that is clear
eswar_babu77
Member level 1
Thanks guys,
will get back in case of ant clarification.
Is there any document which pours more light on it.
