[SOLVED] DFT Compiler: Clock pin not active when scan clock is on
kungchuking
Junior Member level 3
Taiwan
The test_se signal is connected to the TE pin of my ICG cell. I already issued the command
set_dft_signal -view existing_dft -port test_se -type ScanEnable -active_state 1 -test_mode all
but the tool still treats the value of the test_se port as X.
kungchuking
Taiwan
Actually I set both existing and spec view. The following are constraints set on test_se
The existing_dft view is supposed to disable the clock-gating logic in scan-mode. But I don't know why it didn't work in this case?
oratie
Full Member level 6
existing_dft - means the connection of test_se already exist (before compile/insert_dft).
kungchuking
Taiwan
Thank you for your explanation. Now I know what existing_dft really means.
About the DRC error, it turns out that I had multiple test modes in my design. And I didn't specify one before running dft_drc. The problem was solved by issuing the command
current_test_mode INT_TEST
