DFT fault coverage
Hello Friend,
Coverage depends on how best u've inserted the DFT logic.
If you want to improve coverage, follow the rules mentioned below.
Also, if u've fixed all ur violations with "test mode" signal.......it will effect ur coverage. If it is fine fixing ur dft drc violations using "scan enable", go ahead with that.
This way u can improve ur test coverage.
Rest play with the tool commands ....
Good Luck.
Sunil Budumuru
