DFM rules at 45nm, 32nm & 22nm
ajaytronic
Junior Member level 3
Noida, India
endcap 45nm
Hi all,
As on lower technology, dfm rules are compulsory to follow.
Cuold anybody share, what special dfm rules we have to follow at 45nm, 32nm & 22nm.
If anybody having some related document, pls share with us.
Thanks,
Ajaytronic
below are some DFM guidelines, I have followed for 65n and 45n
1>try to give more (diff poly & metal) enclosure over Contacts
2>try to keep metal line width and space more than min +10% to 15%
3>try to increase the field poly width more than min +10%
4>increase the poly end cap
5>increase the spacing btw poly and both related and non related diff
6>try to keep min 2 contacts and if number of contacts are more try to increase the space btw them applies to both diff and poly contacts.
7>try to keep at least 2 vias per connection.
Thanks ninge,
But these are very common rule which we usually follow in analog layout. Pls give some specfic rules at 22nm, 32nm & 45nm like:
1. Stack via not allowed.
2. OPC rules.
3. Orientation of all transistor sud be same throughout chip level.
Can anybody add some more rules???
