tejainece
Newbie level 3
hi,
i am developing an open source IC layout designer called openICix. i have used magic so far. tried microwindows, toped and lasi. never used cadence. i have few doubts,
1) are ploygons necessary for layout design. magic doesn't support polygons. does cadence tools use polygons?
openICix currently uses only rectangles.
2) vertices of each rectangle in openICix can currently only be aligned to multiples of lambda. just like magic. is this ok? or should i remove this restriction. does analog layout design involve vertices that are non-multiples of lambda.
thanks
thanks
