The timing between any path is for rise_path vrs fall_path. The ideal situation would be the gates are sized in such a way that rise_delay = fall_delay. this rarely happens because of the stacking effect and other design considerations. The skewed inverters are used at the timing analysis level with parasitics to try to make the rise_fall and fall_paths as equal as possible.
