tri2061990
Newbie level 5
This is shift_reg code
library ieee ;
use ieee.std_logic_1164.all;
entity shift_reg is
port(
Din :in std_logic_vector(7 downto 0);
clock: in std_logic;
shift_enable: in std_logic;
Dout: out std_logic_vector(7 downto 0)
end shift_reg;
architecture behv of shift_reg is
-- initialize the declared signal
signal S:std_logic_vector(7 downto 0);
signal a:std_logic;
begin
a<=Din(7);
process(clock, shift_enable, Din)
begin
-- everything happens upon the clock changing
if clock'event and clock='1' then
if shift_enable = '1' then
S <= a & Din(7 downto 1);
else S<=Din;
end if;
end if;
end process;
-- concurrent assignment
Dout <= S;
end behv;
This is test code
library ieee;
use IEEE.Std_logic_1164.all;
use IEEE.Std_logic_arith.all;
entity test_shifter_reg is
end test_shifter_reg;
architecture behv of test_shifter_reg is
signal Din:std_logic_vector(7 downto 0);
signal clock:std_logic:='0';
signal shift_enable:std_logic;
signal Dout:std_logic_vector(7 downto 0);
component shifter_reg is
port(
Din : in std_logic_vector(7 downto 0);
end component;
begin
create_clock
rocess
begin
wait for 15 ns;
clock<=not clock after 50 ns;
end process create_clock;
create_data
rocess
begin
Din<="10001100";
shift_enable<='0';
wait for 10 ns;
shift_enable<='1';
wait for 100 ns;
shift_enable<='0';
wait;
end process create_data;
DUT:component shifter_reg
port map(Din=>Din,clock=>clock,shift_enable=>shift_enable,Dout=>Dout);
end behv;
Error
# ** Note: (vsim-3812) Design is being optimized...
# ** Error: test_shifter_reg.vhd(44): Bad default binding for component instance "dut : shifter_reg".
# (Component port "clock" is not on the entity.)
# ** Warning: [1] test_shifter_reg.vhd(44): (vopt-3473) Component instance "dut : shifter_reg" is not bound.
# Optimization failed
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./run.do PAUSED at line 6
Help me,please.I use Model Sim SE plus 6.3f
library ieee ;
entity shift_reg is
port(
end shift_reg;
signal a:std_logic;
begin
a<=Din(7);
begin
else S<=Din;
end if;
end if;
end process;
Dout <= S;
end behv;
This is test code
library ieee;
port(
end component;
begin
create_clock
begin
wait for 15 ns;
create_data
begin
Din<="10001100";
shift_enable<='0';
wait for 10 ns;
shift_enable<='1';
wait for 100 ns;
shift_enable<='0';
wait;
end behv;
Error
