kingmaker
Junior Member level 2
I need to design a circuit based on standard cell
- Use Silterra 0.18 um CMOS process technology
- Use tools from Mentor Graphics
- Circuit that need to be designed is count the number of times of bit changing from 0 to 1
- The input to the circuit is 4 binary bits
let the 4bit binary as A B C D, and the number of times of bit changing from 0 to 1 as X Y Z where X=0 time Y=1 time Z=2 time.
start from table, then use k-map to find the boolean equation. then i draw the gate logic based on the equation with DA. afterward then only draw the layout with IC. is it correct?
