Design biconical antenna, but with ellipsoid /paraboloid
mer_
My question is simple:
how can I draw with cst MWS an ellipsoid or a paraboloid???
Do I have to draw it with matlab first?
Thank you very much.
it is easier to draw in hfss and importing in cst
Hi mer,
You can create the baselines using the macro: "Construct->2D curve", and then sweep the curve around an axis to create the required 3d body.
Good luck,
P.
go to
it is very useful link
Hi mer_
First draw thin solid ellipse then draw little cone few mm from it.
Now pick the faces in these objects and use loft. That's all.
pl
if you can use the function in 3D:
I am also trying to do exp on Ellipsoid
build the ellipse first.
and build x=0
y=sint
z=cost
then use sweep funtion
but I only get the 'empty egg'
