Dell d600 usb port not working
Akintex
Newbie level 2
DELL D600 USB PORT NOT WORKING
it say power surge on usb port .. :wink:
please tell me the solution
Did this just happen spontaneously? Or had someone been tinkering with the connections?...
Are your USB ports showing in Device Manager? If they are, uninstall them via the Drivers tab and reboot your computer, let Windows re-install them.
Is this truly all the information you have about the problem? Not a lot to go off of. It doesn't sound like a driver issue to me, but I suppose that is the easiest thing to try before other things.
installed the driver and but,
Still don't work ------> North-South Chipset Fault (This BGA! chip is on the mainboard).
And rework is wery special. You can repair only rework station.
ta2ctp from TURKEY
Hi.
There is SM for you Dell mabe is usefol ...
Costas
  • D600 SM.pdf
