I need to know is there any other method to find the maximum frequency before synthesis, means during the rtl coding...
Other than guessing based on previous design experience with the same family of parts, no there is not.
If no, then how we decides the working frequency of a design...?
Assuming no prior experience with the same family of parts, then the method is
- Synthesize the design to see what maximum frequency is reported. Do not wait until the design is 'complete', build what you have.
- Based on multiple synthesis results as the design is evolving from the previous step, you should start to get some idea of about how fast the design will run. Now add a timing constraint to tell synthesis what speed you are looking for. Re-run synthesis to see that it still works.
- As you continue to work on the RTL, continue to do background builds to see if timing is still passing. If it starts failing, it could be that you need to relax the Fmax requested or it could mean that new code that you've added is slowing things down and should maybe be scrutinized a bit to see if there is a faster way to implement
Because if we can decide the working frequency only after the synthesis process, then the thing will be danger, because its too time consuming ..
I'm not sure what danger you see, but the clock will come from either an external oscillator or an internal PLL. If you need to change the external oscillator on a board, that is not that big of a deal. It's a 4 pin device. The trouble there might be if that same oscillator is used by multiple parts on the PCBA. But if that is your situation, then you already knew upfront the operating clock frequency that you needed to meet. If the clock is coming from an internal PLL, then it simply means you adjust the PLL parameters to produce a different frequency which will result in a new binary file to download to the device. This is no different then if you fix some logic problem.
As to 'time consuming', I'm guessing you mean the time spent iterating through the synthesis tool. That's why I suggested running synthesis early and often as the design is still being created. That way it runs in the background, when it finishes take a look, but don't sit there waiting doing nothing while the tool is running. This method can also catch design errors that haven't been caught in compiling or simulation up to that point.
Kevin Jennings
