thecolororange
Newbie level 2
state machine delay
I'm trying to change some existing code to improve timing and the quality of the code in general. One of the ways I'm trying to do this is switching from using a single process for a state machine to dividing it into 3 processes (state advance, output, state change).
I'm having trouble with one part of the code, though. In several states, there are delays generated by using a simple counter, like the following:
These worked fine when there was only one process, since that process was the only place I used or modified wait_ctr. With three processes, only the state advancement (access_state <= next_state process gets a clock, so it has to increment the counter, but only the state change process or output process would know when to reset wait_ctr, and they all can't drive the same signal.
If wait_ctr was always reset at the same max value, I'd be fine, but it's used in several places with different max values. Do I need separate signals for each counter? Is generating delays like this bad practice? Is there a better way? I appreciate any input.
when READ_2 =>
if wait_ctr = 2 then
wait_ctr <= 0;
sram_clk <= '1';
ram_action <= READ_DATA;
access_state <= READ_3;
else
wait_ctr <= wait_ctr + 1;
end if;
