Defected Ground Strutcure (DGS) with HFSS
dragonhamada
Member level 1
Member level 1
Dresden, Germany
hfss ground
I have work on filter design (bandpass filter) and i am designing filter with defected ground structure and i was simulate my design with AWR(Applied Wave Research) or Microwave Office.
Now I turn to HFSS to learn and simulate with it
Can anyone help me on how to model the defect on the back metal ?
the defect is an etching area in a metal in any shape like C-shape or Hairpin
attached a photo to the defect
Thanks for everyone
First define your ground plane as perfect E, then draw the C shape structure (3 rectangulars), assigned these elements as perfect H ( slots in a metal). You can simulate after that. Let me know, if you have any problem.
Thanks
Thanks
first i was want to know how to made the defect in the ground(how to etch the C-shape)
and i was modeled
Now
you say to make the ground plane perfect E and the defect as perfect H
why you say that?
i simulate without assinging any of these but the result was not satisfactory
hope you to reply to my question?
Thanks again
Eng.M.Hasanien
why dont you simulate using the perfect E perfect H suggestion?
i cannot understand if i assign the three rectangular as perfect-H before or after i subtract them from the ground?
and if i assign them as perfect-H i can subtract the rectangular or not?
i will try this
Thanks,
Eng.M.Hasanien
hi there.. how could you design defected ground w/ AWR..
do you have any tutorial for design defected ground w/AWR???
LaTeX Commands Quick-Menu:
