DDR SDRAM Interface with Microblaze in EDK
pramodm
Member level 2
Member level 2
microblaze ddr sdram
I got problems while interfacing DDR SDRAM with microblaze in EDK , please any body give solution and give a sample ' C' program how to access the memory in software microblaze???
thank you
access sdram with microblaze
Can you describe what exactly your problem is? Normally, at the end of BSB wizard you should get an option to generate a test memory application.
Please specify also the version of the tools you use and the target device.
microblaze without edk
hi
which fpga and sdram you are using? can you tell in detail what is the problem you are facing?
I got solution to my question
In memory test sample program
hi,
i am not much clear wth ur question.
can u just help m how to use interrupt function in edk . please dont say u can refer example program . if u have any sample program regarding interrupt function can u just sent m .ppppllllllllzzzzzzzzzzz
Interrupt of what peripheral? Each peripheral has its own drivers, including interrupt management functions.
just use a pointer
unsigned long *MEMaddr;
MEMaddr = (*unsigned long)MEMaddr_base_address
*MEMaddr = 0xabcdef10;
