DC2DC with Vin up to 180V Vin
stanislavb
Full Member level 2
Full Member level 2
Could somebody advice me DC2DC buck PS with wide input voltage range Vin = 30v - 180V output 18v and Iout = 0.1A
Thank you in advance
Hi stanislavb
You can use a simple PWM driver and a mosfet and a float driver and inductor and .... to yield your aim .
As for driver you can have look into TL494.
Perhaps this isn't enough for you and you need detailed guidance ?
Best Luck
Goldsmith
For a flyback, the transformer can be a step-down 3:1. This ratio can be made to work with your wide range of supply voltage.
You'll run it at a narrow duty cycle (20 percent or so) when connected to 180 V supply.
Run at a wide (65 or 70 percent) duty cycle when connected to 30 V.
A typical operating frequency is 20 kHz. Then a primary inductance of 10 mH is workable.
