Moha99
Junior Member level 1
Hallo!
I recently bought the recom RCD-24-0.70 series hoping to have a constant current of 700mA and a adjustable voltage since it's clearly stated output voltage "2 - 35Volts/DC"
I have a problem with it... I'm not interested in using some LED'S I want to power some DC appliances under 500mA using this driver.
I bought this at a very expensive price since I'm in a rush and needed it to be shipped quickly could you tell me how can I adjust the voltage? I followed the diagram supplied from the company and I could not increase the voltage I really don't know why came here hoping someone could shed some light into this problem.
Some read the datasheed stating its a "STEPDOWN" converter I doubt that... And yea I have a input of 6Volts DC! The driver requires a minimum of 4.5 volt and a max to about 36 volts DC in.
Thanks!
Here's some info about the driver:
Digi-Key - 945-1123-ND (Manufacturer - RCD-24-0.70)
Datasheet:
Thanks!
Datasheet:
