analog_fever
Junior Member level 3
Just want to know the opinion of the forum. Is it preferred to use exactly the same set of constraints for both synthesis using DC, and STA using PrimeTime?
Does the synthesis tool use the false path specifications, or max transition constraints?
Or can we use a simpler constraint file to do synthesis, and then use a more elaborate constraint file for STA?
