DC level shifter with adder
rutvik1588
Newbie level 5
Newbie level 5
HI guys . I am looking for circuit which can shift my varying 0-10 DC signal(through linear potentiometer) to -5 to 5 voltage level. This shifted signal is to be added with another varying dc signal (0-10 V DC). I have only 10V DC source available. I have tried clamper circuit but could not do the result. So please help me out here m attaching the operational block.
You are asking for a -5v to +5v voltage shifter but the input of that stage is from a variable resistor connected to 10v and gnd so I don't understand where do you expert to get that -5v from?
Alex
Ok, your schematic explains it better, you want to get the difference between the two voltages.
You can feed the two signals in the inputs of the differential amplifier below to get the result, no need for extra stages.
You should be able to figure how to use it to get the result you want...
Alex
P.S. the V1 and V2 names in my schematic do not represent your actual V1 and V2 voltages, they are just the two input voltages
