I want to write a verilog code for transferring data from one memory to another in which i have to define the to memories first and then transfer the data (the size of both memories is same). please help me with a verilog program.
You didn't expose the details of your project, so it is hard to guess what you are trying to do.
But, if you are talking about two internal memories, it can be done by a counter and simple logic to control write enable.
the project is basically to transfer data which is stored in one memory location to another i.e i have to 1st define two memories using verilog and then transfer the data (i.e bits stored in memory 1) to memory 2...now i think i made myself clear can you post some verilog code for doing this please its urgent
No you didn't make yourself clear. Are we talking 2 memory locations (possibly within the same memory chip), or transfer from one memory chip to a 2nd one? Just single transfers or blocks of data?
What type of memory are we talking about here? ROM -> RAM? SRAM? SDRAM? DDR? DDR2? If you have a setup in mind, a block diagram or schematic would help.
we are taking 2 memories in the same chip and we have transfer blocks of data from one chip to another ..
it should be like implementing for example 1kB of two memories then using read and write operations transfer data from 1st to second memory...
