David_
Advanced Member level 2
- Joined
- Dec 6, 2013
- Messages
- 573
- Helped
- 8
- Reputation
- 16
- Reaction score
- 8
- Trophy points
- 1,308
- Location
- Sweden
- Activity points
- 12,242
Hello.
I am working on a power supply that as the EEVBLOG lab supply uses a signal from a microcontroller to adjust a voltage regulator.
A PWM signal trough a filter or a DAC will produce a voltage that will be amplified to adjust a voltage between 0V and 25v and feed to a voltage regulator, if 15 volts from the microcontroller+amplifier goes in to the regulator 15V comes out as a regulated voltage.
But the nois of the conroll volage will be inprinted on the regulator output amd i'm kind of lost regarding how i will produce the voltage.
In the end i will controll two rails with the voltage, one posetive related to ground and one negative.
Both rails have a max voltage of 25V so I'v decided that i need 12-bit resulution to adjust the voltage in 4096 steps, but i don't know if i should go for 12-bit PWM and filter it heavy or does a 12-bit DAC have the potential to output a clean DC voltage?
I am prepered to go to some lengths to get a realy clean output.
