fireball003
Full Member level 3
My microcontroller ADC can take input from 0-5 volt. But my input voltage is much more than that. Same for Direct current. Which circuit will help me to reduce the voltage using a known equation ? (So that I can calculate and get the original voltage and current value while computing inside microcontroller.)
Is Op-amp helpful here? Then what would be the circuit?
Thanks a lot
Thanks a lot
