preethi19
Full Member level 5
Hi i have attached an image of a very simple ckt.
I able able to find the Charge Q of the capacitor and the Voltage across the two capacitors. Can anyone pls let me know what is the current through each capacitor 12uF and 6uF. I know current through series capacitor will be the same but how to calculate individually for both and see that both the current calculations are turning out to be the same.
Adding both the capacitors the equivalent capacitance is 4uF. And voltage across 12uF is 1.33 and that of the 6uF is 2.67.
The formula for current is I= C dV/dt. But in this case voltage is not varying so i guess it simply becomes I=CV.
So current across the 4uF capacitor (the equivalent to 6 and 12uF) is I= 4uF x 4V. (since Votlage at point X is 4V) so I= 16uA
So now for individual capacitors the current through 12uF is
I=12uF x 1.33 = 16.02uA
And current through 6uF is I= 6uF x 2.67 =15.96uA..
So current is similar in both through 12uF and 6uF.
Is this the right way??? can anyone pls correct me if wrong.
