brain79 said:One thing to have on mind is what need your circuit, high or low impedance.
No, I knew them already. I wanted a different explanation.... I dono how to tell....DarkJedi said:I hope i made myself clear.
kgl_13gr said:Remember that by (Millman's I think ) theorem you can replace a (non-ideal) voltage source with an equivalent current source (and conversely) in a circuit's analysis.
pico said:Voltge is like the pressure of water and current is like the flow of water. Voltage source means measure the pressure of water at that point and current source means measure the flow of water at that point rather than measure the pressure.
