mmitchell
How to interpret current sensing resistor’s current capability?
For example, if I see a current sensing resistor with R = 0.02Ω, “Power” = 0.1W, does it mean:
0.1W = Imax2 × R ⟹ Imax = (0.1/0.02)1/2 = 2.236A?
Resistors satisfying these requirement is actually quite small: for the 0.1W type above, an item such as Vishay WSL0603R0200FEA has only 0603 size. To some extent, I just feel this calculation too simple to be true.
On the other hand, I have seen boards using 1206 or even larger size current sensing resistors for current < 1A, and have resistance 0.02Ω. In these cases, P = I2·R < 12·0.02 = 0.02W, so that the 0603 Vishay WSL0603R0200FEA could already suffice. Why would they still use 1206 type instead?
Matt
Matt
