danda821
Full Member level 2
I am wondering if there is a simulator which simulate current distribution in 1D. IE3D can simulate current distribution in 3D. But I need to know the current distribution along a t-line. Thanks.
jian said:Hi, danda821:
IE3D solves the surface current distribution. You can also visualize the current distribution on the surface too. In case you want to find the current distribution at a specific point or along a line, you can display the current distribution on MGRID and select File->Save Current Density Data for the values in ASCII files. You can write a simple parser to post processing the data. For example, you can try to find the current along a line, etc. Regards.
