A
aveore
CST MWS: Circular Waveguide - How to interpret the simulation result ?
[With what software does the given design is based on: CST Studio Suite 2012/CST Microwave Studio 2012]
I have build a circular waveguide with tapered extruded sections at each ends of the waveguide. I have also successfully simulated the design with 1 or 2 warnings and got results as well, but not quite sure of understanding the simulation results. Could somebody help me to interpret the S-parameter (magnitude vs frequency) outputs of this waveguide. I have attached a pdf file of my design with respective simulation result in it. Below is some specificatrion of my design (if in case somebody need it).
Design Specification:
Regards,
Aveore
- Frequency Range: 8GHz - 12Ghz
- Material Used : Aluminum [Type: lossy metal]
- Boundary Condition: Xmin & Ymin = Conducting wall, Zmin = open (add space)
- Field Monitors : E-field [Fmin=8 GHz, Freq=10Ghz, Fmax=12Ghz]
- Solver: Time domain [Mesh type=Hexahedral, Accuracy=-40dB]
Regards,
Aveore
